Hello all, new to Suzuki. I have been reading a lot of posts about front end wobble or shimmy. I just bought my wife a C50T Trike with the Lehman kit. When I bought it the front end wobbled but the trike had been sitting for years in the same position and the tire was dry rotted. Got it home and went thru the entire bike front to back including replacing the tire and having all the wheels balanced. Wobble improved but still present.
I then made sure the bike was aligned by measuring from the front axle to both middle tear tires and measuring from the lower center frame to both back tires. All looks good
I took the front tire off again and I have 0 head play and the steering is smooth and true.
I them installed a stabilizer from the front fork to the frame, steering improved a bit but still present.
So my next thought was since the front forks are a bit soft was to change the fluid. Has anyone done this without removing the front end? I have an electric oil pump with a small hose and was hoping just to loosen the top tree, remove the nuts and suck out the old oil and put in new.
