1 - 16 of 16 Posts
FREE:
1) Handlebars Risers. Took off C50 2008. - SOLD
2) A pair of non-OEM saddlebags brackets from a 2008 C50. Paint is peeling in places, some surface rust but should clean up nice. Made of thick tubes and has three bolt mounts on each in addition to two fender struts mounts. I had these holding semi-rigid saddlebags before upgrading to hard shell saddlebags. You would need approximately 100 mm m8 bolts to mount this on C50. I’m not sure if this works on M50 or C90 or earlier pre-Boulevard models. Distance between main mounts is about 8.5 in on center.
You pay shipping - probably about $10 in continental US.
I still have them. Let me know the zip code for shipping. Note: no bolts included, just the brackets.
The zip is 98230. Where do these mount?
On the sides of fender struts. Watch the video quoted below: in the first ~20 seconds of the video you will see how saddlebags supports look installed. This forum has a ton of posts about saddlebags, you will most probably find something with pictures.
I'll let you know the shipping quote later today.
1 - 16 of 16 Posts
