Fiamm car horns instead of Stebel under right side cover
1 reading
6.7K views 31 replies 17 participants last post by  Moto-Suzzi G50
#1 ·
I got these at a car parts store and fit them under my right side cover
I didn't want the stebel, it was tight but with a bit of patience and bending the brakets that came with the horn it all worked well
It's very loud and cost me $30 Canadian
#4 ·
Interesting and cool!... Do they get muffled at all when the cover goes on?..
Should post a pic with the cover on.. cool there is room . doesnt look like there would be at first glance!...
Nice job.. No problems with heat from Pipes?...
Dave
#6 ·
Yup I put a Fiamm highway blaster low-tone there two years ago to complement the stock horn and its good and loud, definitely gets attention when I need to use it. On some of the many threads about horns I posted a link to a webpage where tests were made of the leading horns. I've lost the link now but its there if you want to compare the different types of horns. I remember the tests yielded some surprising results.
#9 ·
So can you just tie into the existing horn wire or is a relay still needed?
Nice install BTW!
I was planning on a stebel so had already installed a relay and took the power from there, for that reason I don't know if you could take it direct from the existing horn wires(used those to trigger the relay)
It's different from everyone out here! and that's what I was aiming for
:twisted::twisted:
#15 ·
Hi Shawn, used your PDF, I remember using a relay because had to run to autozone twice to get parts :) It's interesting that some mods remind you of a certain place and time. My horns were put in at TOTT (that was a VR rally for those who don't know).
#16 ·
I know the relay is a must for larger louder horns. Kinda thought that without a compressor maybe a guy can get away without the relay.
New members might read this and figure the same, so I asked to be safe.
As usual from the VR, instant answers with good advice and instructions ta boot! :wayhappy:
#20 ·
#32 ·
I mounted them at the top outside corners of the radiator cover. There is one on each side. They are loud and move people out of the way.
Thanks for the pic. Nice Job.
I really like the look , your mount location and the sound of the Wolo 225s. I haven't found these in Canada at a reasonable price yet. Shipping from the USA seems to be the deal breaker for me at the moment. Can Tire up here has a repackaged but not rebranded Stebel Nautilus (Chrome) that I will pick up if it comes on sale before I can find the Wolo Chrome hi and lows.
#23 ·
Shouldnt the horns be pointing thataawayy :biglaugh:
The magnets are in a cover shaped such a way that it makes small sounds large. Try tapping the horn and u will hear a real loud sound despite the small tap. They are recommended by the manufacaturers to be mounted with the opening face down.
Btw it looks soo good. Real nice job.
#29 ·
A couple of comments:
1. Any cover will reduce volume, even if not fully enclosed. If you have a smartphone, you can measure the volume on your own using a decibel meter app. I have two Fiamms mounted exposed and they are as loud as a car's horns.
2. I have read in several places that running an air horn or two stock/Fiamm horns without a relay risks frying the horn switch. I bought a plug-and-play harness from Eastern Beaver. I forget the cost, but it was less than the cost of replacing the horn switch.
#31 ·
The cover does not change the sound that much, it is still plenty loud. WAYYYYY louder then the stock horn. I have the two Fiamms, hi and lo, and over the 7 years since the install I have used plenty of times—hate cell phone drivers! I did use a relay, it's a couple of bucks and a few more minutes to install.
