2006 Suzuki Boulevard C50T
I started hearing this noise from the exhaust and dont know what it is. After I let of the throttle, whether the bike is moving or stationary, it has some kind of noise,,,like when you stick your tongue out and blow a little air thru like, dang that was tough,,, anyone getting what i am saying and can help?
What have you done to modify the exhaust? It sounds like an exhaust leak or a bad header gasket.
Discussion Starter · #3 ·
nothing since i get it,,,I am thinking I may have not gotton a nut tight enough when I did the valve job.
Discussion Starter · #4 ·
I know exhaust was changed to Vance and Hines pipes then debaffled and never reprogrammed.
Discussion Starter · #6 ·
You wouldn't really need to retune for just removing the baffles. Wouldn't make a large enough difference in flow to mess up the tune.
But it is not stock exhaust either
From your previous post, it sounded like the bike was originally tuned for the exhaust and then you removed the baffles and didn't re tune it. So the bike was never tuned for the exhaust? Do you have the stock intake on aswell?
