Anyone used the Dynatek F.I. controller on there C-50? it can be programed to lean out or richen the mixture as the power commander will do, but it is cheaper and no usb needed.
I never heard of it but the fact that it can lean out AND richen the fuel mixture is a VERY good thing!
as you find out info, please post what you find.
I got 2 questions:
1) do you have to do any splicing in the wire harness to install?
2) is it programmable using data or does it have little knobs on it?
Dynatek F.I. Controller
Just ordered this unit and will let you know the results. There are 3 base settings that allow you to "Grow" your system. base # 1 is used for after market air filter change only, base #2 is for after market air filter change and after market pipes with baffles IN, base #3 is for after market air filter, and 2 into 1 pipes or pipes WITHOUT baffles. You can then go into settings for each power curve-- low--med--high and you can lean out or richen in each curve + or -- 20%. Once I install this I will be just changing air filter (base #1) after that in a week I will be putting on the V&H straightshots (base #2) if I install the unit in a place like the tool box all I have to do is take off tool box cover and turn the little screw. Hope this works out OK.
