1 - 12 of 12 Posts
· Registered
Doing the DJ Mod on an 06 C50. I read the instructions several times but I have a question if anyone knows please.
I'm going to modify my current C50 drive shaft. Once the 3/16 is trimmed from the end, does it need to be rounded slightly like the original? See pic attached.
Also, I live in Western PA. I can cold call a machine shop I guess, but is there anyone around my area that has a recommendation for this, or is there someone I can send it to for machining that knows the deal?
Thanks
· Super Moderator
Welcome from Kennesaw GA!
I'm afraid I don't have the answers to your questions, but hang out a bit and someone who does will probably come along.
· Registered
It is not the END that needs to be shortened, but the SHOULDER of the splines that needs to be cut back 3/16". Just cutting the end will still make it too long and cause the shaft to catastrophically bind.
· Administrator
They both need to be pushed back 3/16"
A chamfer on the end of the shaft to the bottom of the splines will help during installing.
Reactions: Skrapiron
· Registered
Discussion Starter · #5 ·
Yeah, I know the shoulder needs shaved back 3/16 also. I don't have any questions about that.
But when the end gets trimmed off 3/16, the end of the shaft will be flat across. Do the edges need to be rounded off a bit like the original pic I posted? That's my question.
· Administrator
No they don't need to be rounded, but make sure your deburr them with a file after you add the chamfer.
· Registered
It isn't rounded, it is chamfered. (Google is your friend if it is a new term) The flat corner around the entire circumference is cut off at a 45-deg angle. This allows for easier insertion without perfect alignment.
· Registered
Discussion Starter · #10 ·
Okay, so I learned a new word, thank you!
So who adds the chamfered edge? The machine shop when they trim off the edge? Or me after I get it back with a file or something?
This wasn't mentioned in the DJ Mod instructions.
· Administrator
Have the machine shop do it when they cut the end back.
Reactions: SSquire and GeorgeF
1 - 12 of 12 Posts
