1 - 11 of 11 Posts
Was practicing low speed manuveurs using friction zone. When engaged into first gear it died. Put in neutral, started fine, engaged clutch died again. Let cool off for about 20 mins, started and first engaged just fine. Seemed hot. What would cause this. When hot idled fine, but putting into gear causes to stall?
Check the kickstand. There is a switch that cuts the motor if the KS is down even slightly. Report back here when you find the solution.
Reactions: CDUBL
My spring is a little sprung I guess, and I have to push it all the way up sometimes or it cuts out on me.
Same here. I replaced both springs last summer. Motor was cutting out at highway speed. Took me a week or so to determine the issue. Everytime I coasted to a stop, leaned out the kickstand, it started right up. Pull out into traffic and then a few miles down the road, it would quit again. Dealer did not have them in stock so I matched up the springs at an auto parts store as brake shoe return springs.
If I'm reading your post correctly, it was after it "cooled" a bit, that you were able to put in first without stalling. Very possibly your kickstand might have been positioned up better but I would also check your radiator coolant. I believe Suzuki recommends changing it every 2 years. Yours could be old. My 2 cents.
+1 for the kickstand switch. Never had issues with mine before I sold it, but can totally understand how it would fail.
Ordered kickstand springs, and was going to order kick stand switch. Can't find the **** switch anywhere except on ebay. When I look the fische nothing shows the kick stand switch. Where can I get new?
I have fixed a lot of sticky switches with WD-40. It's non conductive so it won't short out.
Absolutely correct! Thanks for the tip. Called the shop and they of course said to bring it in. Searched the blog and got the answer in a minute. Good stuff, thanks very much!
1 - 11 of 11 Posts
