I wanna do the License Plate Laydown but with a curved frame. Anyone done similar with a Kury or other curved plate frame? Just wondering if the curve radius on these plates (8-12 degrees) would be a nice fit with the curvature of the C50 rear fender...
You could try making a sample one outa some cheap tin or sheet metal and see how it looks on the bike and decide if thats the look you want.
I just bent mine and bolted on a thick "L" shaped aluminum bar, attached to the bolt by the rear axe drum. Little shaky when moving, but not enough to bother.
Ground clearance is something to consider making sure its high enough it wont grind as you lean over in a turn. Iv done some mods in the garage on a stand only to lower the bike and find out the mod looks great but interferes with the bikes riding ability.
