I just put on V&H Cruzers for my 05 C50 and the Cobra fi200. The instructions for the fi200 says that after the bike has been started that only the green led should be lit. Im getting all 3 still lit after its started. The directions say that if all 3 leds remain lit after starting the gray/white wire is installed incorrectly. I've checked it numerous times and it is gray/white to gray/white. Anyone else have this problem????
Moving this to Jets, Injectors & Pipes - hopefully you'll get an answer. Good luck - & you're gonna love those Cruzers! :wink:
Cricket
My connectors did not make good contact with the wire until I soldered them. This sounds like the same problem I had.
Good luck.
Ive been riding without the fuel processor and surprisingly it seems to run fine. Maybe I don't need it.......Ill run it for awhile without and see how it goes.
