Nice!What are you doing, exactly? Are you replacing the factory bulb inside the headlight assembly, or are you trying to replace the entire reflector and light assembly inside the trim ring? The bulb swap is easy - video link below. If you're going aftermarket, good luck. None of the screws on the bike are PHILLIPS head, they are JIS meaning a regular phillips head is too steep and it will round off the fastener.
I bought a whole new headlightWhat are you doing, exactly? Are you replacing the factory bulb inside the headlight assembly, or are you trying to replace the entire reflector and light assembly inside the trim ring? The bulb swap is easy - video link below. If you're going aftermarket, good luck. None of the screws on the bike are PHILLIPS head, they are JIS meaning a regular phillips head is too steep and it will round off the fastener.
