1 - 15 of 15 Posts
Help.. During warmup bike runs normal. After a few miles,when coming to a stop or even slowing down to idle speed,bike will cut out. Starts right away after cutout. Sometimes it will backfire when it cuts out.I have 23k kms on it.On the open highway or driving on city streets all is normal. The tach is reving about 1100rpm when I hear it miss and quit. T
I have checked for loose connections. Bike shop can't help till next Thursday
Thanks for any help.
Banned
have you heard the fan coming on?
any indication from the warning light as in overheating?
has it only been happening since your last fillup?
has maintenance been done? valve adjustments?
Discussion Starter · #4 ·
Yes. the fan comes on.
No warning lights come on
Started happening just before I put it away last year.
Haven't had any maintenance done lately.
Hopefully the dealer will be able to figure it out whan he reads the fault codes
bike quits running
My 04 did this two times last summer. Both times it was hot outside and both times I was in traffic with the engine idling. I never could find out why but since I used a fuel additive I havent had any problems. Let me know if you find out what caused this because it is a bad feeling not knowing what the reason was and if it could happen again on a road trip. VolusiaThornton
I'd check to see if your idle screw or fast idle screw is back out from vibration. It's happened on other bikes i've had.
Do you feel a lot of heat rising from the engine when stopped?
I think a hot stall might be caused from an A\F lean condition.
By any chance have you adjusted the slack in the throttle cable?
I took the post as this coming thursday the dealer could look at it.
mightydog said:
i think the dealer's had it since thursday. wonder how long it takes to read them codes.
Banned
ahhh, maybe so. i was thinking from that being posted wed, that thurs meant the next day.
Discussion Starter · #13 ·
Sorry fellas, been offline for a bit. Dealer called yesterday. He says the OEM tach installed just before I put it away last year,is causing the problem. Something about Suzuki having 2 coils. He disconnected one side and all was well. Of course the tach read half the revs. I'll try a search here for similiar problems. Thanks for the suggestions.
PS If Sunday is tomorrow and I say next Sunday as opposed to this Sunday ,that means one week later.
If you only mentioned you added a tach with no adapter. You need the resistor/diode adapter for it to read and run correctly on the C50.
Banned
you're probably in the majority because i've had this problem my whole life. :? to me, that's taking the "sundayness" away from tomorrow. :lol:
1 - 15 of 15 Posts
