I got a new to me 2006 Suzuki Boulevard c50 vl800 with just a shade under 15k mileage.
I’ve been working to bring back to life, it had been sitting for a few years in a garage. Finally got it were I felt comfortable to start and run it. I then I had a hiccup as it started to blow(smoke stack style) white smoke out the front cyl exhaust pipe. Shut it down and seen what I believe is water draining out rhe bottom of air filter housing. So I’m taken it the front cyl head gasket has blown. Tho I won’t know for sure till motor is out of bike and todown.
What other items might I be looking at/for while I have it tore down??
Where’s a good place to source a full gasket kit? (Rather not piece one together)
Anything else besides multiple gaskets, o-rings, and fluids might I need to replace?
My Research has showed one item. The timing chains can stretch prematurely. Not sure this would be a concern on a bike with about 15k on it tho.
Plan is to start tomorrow on removal then. Once I get it out tear down before I order parts to start the rebuild process
Thanks for any info or help,
AJ
AJ
