No really that's what it is doing. It lost all power to the rear wheel. Bike runs fine clutch is new after the incident. SO basically i can run the bike and the rear wheel will creep but no response to throttle and i mean creep with bike on a stand she hardly rotates. If i rotate the wheel by hand there is a slight to moderate grinding noise around the pinion area. It has a bad grind when I let the clutch out and apply power. Looking for ideas im thinking draft shaft into pinion gear is jacked but i cant break it down. I Pulled out the Dive shaft and shes a rusty not sure how that happened but i cant remove the grease cap to removed the Shaft from the Drive. Any Ideas ??? I was told the Rear end was rebuilt and everything rotates as it should but She wont move. Can upload videos if need be....
Video - YouTube
Video 1 - YouTube
Video - YouTube
Video 1 - YouTube
