1 - 20 of 21 Posts
· Super Moderator
Since it would mean that I could cook bacon and tell my wife that I was just gassing up the bike... I approve! :wayhappy:
The only problem is that I would just get super hungry everytime I rode it.
· Registered
Hrrrrrrrmmmmmmmmmm........
uh....
I see issues....
1. if the exhaust smells like bacon then there are proteins,smoke and salt residue making it into the injectors and cylinder.
2. Several of the compounds responsible for the smell and taste of bacon in bacon fat turn into a sticky nasty mess when heated/burned.
3. burned further the sticky nasty mess becomes abrasive carbon grit...which in a cylinder coated with sticky nasty mess will remain trapped, stuck to the cylinder wall.
Meat fats are far from ideal for use in an engine unless refined and stripped of the components which will cause problems (clogged injectors, scored cylinder walls, gummed up valves and pistons, etc.)....with the fuel refined to the point that these are no longer a threat, the exhaust smelling like smoked cured meats is highly unlikely.
· Registered
uh....
I see issues....
Only one word to counter that argument BACON
· Super Moderator
uh....
I see issues....
You're taking it way too seriously dude. It's bacon! Bacon makes everything better!
1 - 20 of 21 Posts
