I have seen cheap led lights and they suck compared to the radiantz and custom dynamics LEDs.Or you can buy the strips on Ebay for like 5$ and wire them in. i put them on my sport bike and if i can do it about anyone can![]()
If you don't want the dim function then get the blinker genie out of the circuit and they should flash in unison.Well after much contemplation, I stuck with the cheap route. Chose the Blinker Genie due to the fact I wanted the lights to turn completely off during the blinling process (not dim to bright)
1. 2x 5055 Strips from Autozone
2. 2x Blinker Genies from CustomLED
** Lights will not flash in unison with the lollipops (unless you convert to LED and run all front lights off of the Blinker Genie)
Here is a video clip.
Blinker Genie w/ Batwing LED - YouTube
Dont want to eliminate the running light function.If you don't want the dim function then get the blinker genie out of the circuit and they should flash in unison.
Are you sure about that? Cause NC Law is that we don't even need turn signals.Here its gotta be yellow/amber for blinkers or they won't pass inspection on the front...
No issues here in Georgia. I checked with the GA Dept of Public Safety before my install. Now --> strobing white lights is another story..Here its gotta be yellow/amber for blinkers or they won't pass inspection on the front...
That's not an issue with this design. The law may say that you have to have yellow/amber blinkers, but it doesn't say you can't have others, right? He's still got the factory lollipops on there, so he'd be in compliance with the law.Here its gotta be yellow/amber for blinkers or they won't pass inspection on the front...
