I could have sworn the heat shields were welded, but I admit I haven't tried to take them apart either.When did they start welding them on?
Mine are attached via clamps welded to the shrouds and the raised sections are attached with screws.
To fully answer the O/P tiny and butt ugly.I have a 2004 Volusia 800 and was just wondering if the shrouds come off the stock pipes.
If so, what do the pipes look like without the shrouds?
I tried searching and could not find any.
Why not remove the boot guards, the little shiny bits, then wrap with the heat shields on?Thanks.
I plan on wrapping my pipes anyways so I figured if the size was ok I would just go that route.
It appears that option is out the window.
I figured it would look lumpy if you did that.Why not remove the boot guards, the little shiny bits, then wrap with the heat shields on?
They are about 1" diameter pipes......scary thin.To fully answer the O/P tiny and butt ugly.
