2006 Suzuki Boulevard C50T
So the wife got me an air horn for the bike,,, Cant say that I can find a GOOD spot for it LMAO,,, ANY suggestions??!??
Lower front frame cradle is the best location.
Reactions: ShelbyGT6869
I think most put it left or right of the Rad. There are frame bolts that the Crash bars would mount to. A bracket mount to there.
You would be best to wire a relay direct from a fused line from the battery. The horn may have come with a relay. Relay can go inside the headlight bucket. FYI If you add anything like conventional Spot lights or heated gear you should have a relay for that as well. The ignition switch cannot handle additional loads without melting. The OEM light bar connector runs through the ignition and can cause a melt situation at some point even with the lower wattage OEM light bar bulbs.
