· Registered
Hey guys. On my 2008 c50, I’ve had a Kand N filter for the last oh lets say 15 years or so. I recently bought an oem filter and was going to put that on. I don’t know why. I guess at one point my bike had cobra pipes and a power commander which I took off years ago and just kept the air filter. I went back to the stock pipes. Anyway it seemed like there should be a rubber gasket between the chrome trim and the air filter. So I looked it up Motosport and found this. Hmm, yeah there is something. Seems like it would be more aesthetic since it it before the filter? When I received it, seems like its too small and not really any way to put it on. What am I missing? Trying to attach some pics.
Automotive fuel system Automotive lighting Fuel tank Automotive tire Hood
Font Tree Rectangle Display device Personal computer
Table Input device Wood Peripheral Plumbing fixture
· Registered
Discussion Starter · #2 ·
The gasket that I got is in the chrome housing and inside the air filter housing in the pictures so you can see that it is too small. Its actually c shaped but the channel is on the inside instead of one of the sides.
· Registered
The gasket I have goes on the outside lip of the cover itself and forms a seal into the air filter housing. It has a channel built into the gasket to "grab" the edge of the cover and bind down when you tighten the bolts. The one inside your cover is too small and I can't figure out what that would go on ?
· Registered
Discussion Starter · #6 ·
The rubber gasket goes around the filter so you must have a C channel, verify that it is.
thanks. Yes I see it. Motosport can’t seem to figure what is wrong either. I feel like I ordered the correct part. One difference is my bike doesnt have those two little 90 degree tubes. My manual shows the tubes too.
· Registered
The two small 90 degree tubes, I understand, were only included in the 2001 model, later they were removed. My C50 is from 2006 and it doesn't have them either. What I send is the service manual for the VL800 that I have, which goes from 2001 to 2009. The first chapters are the same for all years. It changes in 2005 because they eliminated the carburetor for electronic injection. Check part number 13746-41F00 Gasket
Automotive design Organism Automotive lighting Font Line
Font Screenshot Number Parallel Rectangle
· Registered
Discussion Starter · #8 ·
Yup. Thats what I ordered. They want the vin number of my bike so Ill send them that next.
