I am quite content with an H4 LED bulb - bright and decent beam pattern. What is the advantage of a projector headlight?
Any issues with overheating in the headlight housing?I upgraded to this, it's cheap and effective. No mods needed to install. I rode my bike once at night with the stock light. Horrible. This, this is pretty good.
I ended up installing the same bulb. I actually found it used, guy tried to use it with some fancy headlight controller, didn't work. No instructions but installed very easily. There is a lot of room in the Suzuki bucket. I stuck the ballast part to the side of the housing with some body molding tape i had laying around and stuck a couple pieces of HVAC high temp heat tape around the closest wire harnesses to the heat sync for good measure (probably not necessary) So far, so good. Beam looks good. Have NOT yet actually ridden at night to compare said headlight to halogen.[/url]I upgraded to this, it's cheap and effective.
