1 - 13 of 13 Posts
A really quick question: Am about to glue some fresh rubber pads onto my floorboards. These were inexpensive floorboards, and the rubber on one came off while I was riding in the rain one day. I bought replacement pads, and am getting ready to (1) grind the bare floorboard surface a little to give the glue something to adhere to, and (2) glue on the rubber. BUT what is the best adhesive to use for this? Silicone, or Gorilla Glue?
Any weatherstrip adhesive, like TroyAK stated.
Locktite, 3M, or Permatex brand.......they are all fantastic weatherstrip adhesives.
++++++ on contact cement
Make sure both the metal and the rubber are very clean before applying the adhesive. I'd use something like denatured alcohol to clean both surfaces first.
I like a good silicone when gluing rubber. Sometimes glue will harden and become brittle with age, and adverse conditions - silicone stays flexible and will remain watertight.
+1 on the cleaning solvent before you start. The metal not only should be roughed up, it has to be as clean as possible. I used Automotive GooP on my floorboard rubbers and they stayed on really well. I know Advance autoparts carries it but it should also be available at virtually any hardware or auto store.
Good cleaning and Contact Cement is how I reglued one of mine on. It stuck for years without and issue... probably still stuck with the bike's current owner!
1 - 13 of 13 Posts
