So in 5th gear anywhere above 60 I'm sputtering when I get in the throttle gets to 60 wide open just fine but after 60 it's like it's misfiring can't even make it to 70 if I try to give it any more than 1/8 throttle it starts the sputtering and losing power it slows down if I stay in the throttle but if I drop the throttle below that 1/8 it's like it's a sweet spot to maintain speed at 65 on flat land
Rebuild the carburetor, change the spark plugs, and check the valve stem to rocker arm adjustment.
What they said , does pulling the choke make any difference?
