Good day Gents,
Appreciate this forum, has helped me sort out a few problems in the past.
So here is my story i would like to share,
I have owned my M50 boulevard now for 8 years and its on +/- 32 000km.
I drove over some train tracks and a piece of metal flat bar punctured by oil filter.
I came to a stop and switched of the engine, went and bought a new filter and oil.
Started up the motor and no issues, GREAT,
But then after a short while a heard a slight ticking, Valves I thought , Right?
Did the valve adjustment, No success.
Did some reading on this forum and other sources and a lot of people said they have this noise.
Some said it was normal, some said that's just how they were built.
I couldn't find any rock hard info so i said to myself, let me ride it some more and see what happens.
The knocking became worse after some considerable riding.
I was now convinced it must be bearing.
The noise was now distinctly coming from the bottom right hand side of the crank case.
I could no longer drive the motorcycle as the sound was becoming alarming.
So the current situation,
I pulled the motor and stripped it down completely.
I could not find any severe damage to the crank, crank bearings or the conrod bearing.
I even took the bearings and piston to my suzuki dealer and asked them to check if i am missing something.\
They did this free of charge, we have a pretty good suzuki dealership in my town.
So maybe piston slab? Also now sign of piston slab.
So I still ordered new bearing and will replace them when they arrived.
The advice I got from my suzuki dealer is the finely inspect every part as I reassemble the engine.
The engine was never opened prior to now.
So any suggestion are welcome and i will keep u updated as I do this build and hopefully i will find the problems and be able to help others aswell.
Regards, Alwyn
Regards, Alwyn
