1 - 2 of 2 Posts
there's almost no info on replacing u-joints on my bike on youtube.Im thinking it will be about the only way to change u-joints other than pulling motor,and thats dropping the swing arm.if anyone has any helpful info it would be greatly appreciated.:surprise:
If you drop the back wheel, then unbolt the rear drive and pull it out of the drive shaft tube, you can sometimes get the u-joint out by cramming an the end of a broom on it and wiggling it out. Other than that, you have to pull the motor.
1 - 2 of 2 Posts
