1 - 11 of 11 Posts
My bike runs fine at idle give it fuel it cuts out replaced fuel pump both coils both plugs oil change replace the ecu still no luck I'm open to suggestions
First post needs a hearty welcome....Greetings from Penciltucky....
Greetings from Indiana.
Are you sure it's a fuel problem and not an air problem? Could be injectors or something is blocking the airflow. Did you replace the spark plug wires?
Have a look at your air cleaner/filter. If its running on idle, its getting fuel. Could be a dirty air filter. Hope this helped.
1 - 11 of 11 Posts
