1 - 3 of 3 Posts
Hello all,
I have a 2007 Boulevard C50 FI that is having issues. It tends to idle a bit rough, but when I start to go, adding throttle and releasing clutch it will bog down and die. If I'm real careful and feather both I can get it going, but if I add to much throttle (not gunning it, just normal) it will bog down and die. If I do get it going down then road in second or third gear it surges very badly at a constant throttle setting.
I had a mechanic look at it and he thought it might be one of the intake air pressure sensors, but wasn't willing to guess since a new one (there are two) from Suzuki is $250. I found a third party one and a used one and swapped them out. No change. The spark plugs have been changed, no help. The air filter did appear pretty dirty so I swapped it out, no change. I've checked the voltages/resistances for the fuel injectors and they are normal. Took off the air intake and didn't see any cracks or damage.
I am at the limits of my knowledge at this point. It's been a great bike until this season. Anyone have any ideas? What could be wrong, what I need to look at next?
Thanks in advance.
To run properly, you need air, fuel compression and spark. You don't state how many miles are on the bike, or whether you have ever performed a compression test, or adjusted the valve clearance, so I would start there then move to other causes. If the compression is good and your valve clearance checks out, my guess is you are experiencing a fueling issue, either with fuel pressure from the pump itself, or from the fuel injectors. Those can all be removed and tested individually.
It's got about 17k miles on it. I will see about checking the compression and valve clearances.
Thanks.
1 - 3 of 3 Posts
