1 - 2 of 2 Posts
when you switch the key on the choke motor keeps trying to open. It has stripped the plastic gear out. i have put two throttle bodies on it the same thing keeps happening. If you start it the choke butterflies start to close and choke the engine. It does not show any codes on the computer. If anyone has any suggestions i don't know where to go from here.
I had problems last December didn't know what was going on until I saw the black cable was disconnected (from the white connector between the fuel pump and the wire harness) not saying that's what the problem is, but worth looking at. Good luck!
1 - 2 of 2 Posts
