wanting to know on the 2005 suzuki c50 blovard 800cc if can bypass the in tank fuel pump and run external fuel pump as long as it has the same pressure as the in tank pump
I see no reason why you couldn't, as long as the pump has good fuel flow to it and is never starved of fuel. I believe the factory pumps run around 45psi and the system uses a fuel pressure regulator...
