· Registered
My 05 C50 will not ride. Starts up just right idles but the idle is inconsistent. I installed new spark plugs, new fuel pump assembly, and one new coil injectors and it ran fine for a while now it won’t run without bogging out now. It has a k&n air filter, cobra pipes with the tuner set correctly. I am thinking it’s the TPS or the one coil I didn’t change. Bought the deal mode switch no code just _c00. The check comes on when I’m giving it gas trying to ride it but then goes away and doesn’t leave me a code. I would like some advise before I spend another $200. Thanks!
· Premium Member
Did you check your fuel lines ? They get old & clogged.
