Do the stock mirrors have a ball swivel for adjustment or do you have to loosen nuts to adjust them while stopped? I could adjust the mirrors by hand while driving on my older bikes but not sure on the c50. Thanks for help.
The mirrors are ball mounted. The steams are nut tightened.
I can't move either mirror by hand so am wondering how to break them loose so I can adjust them on the road.
Take them off the bike. lay them on the work bench and spray with WD 40 or some such lube so it runs down into the ball joint. Put the stem in a vice and begin working the ball mount back and forth in different directions a little at a time until you get them to move. then come back and ask us how to tighten them up cause they won't stay put!:biglaugh: All this is assuming you have OEM Mirrors
