Heeling, ftp. I have a 04 vl800 that I have replaced the fuel petcock, 2nd air valve, fuel pump (not in tank) & had the carb rebuilt... I still can't get it to crank. I replaced all the fuel components because when I put I bit of fuel in the fuel line it would turn over. Now that I've replaced everything, it won't do jack. Do I need to prime the fuel system somehow? Is it possible that the new vacuum lines I put on aren't tight enough? I've vacuum tested the new petcock and it will release fuel when a vacuum is applied. I'm so close to getting her, I can feel it. Anything helps, thanks.
