Discussion Starter #2
The ticking noise from back cylinder and has alot of hold back now changed oil and didn't help and it has 38xxx miles on it
Ticking is normal for these engines. Excessive ticking is not. It all depends on where the noise is coming from. In the upper cylinder excessive ticking usually is the result of a valve problem. In the lower motor, it is usually a loose cam chain. Neither is particularly catastrophic (yet), but needs attention. The best way to narrow it down is to use a screwdriver as a stethoscope. Put the tip of the screwdriver on several places on the motor and put the handle in your ear. Move it around until you pinpoint to source of the ticking.
