2002 Suzuki vl800
My starter switch won’t work I have gone and put a new switch’s on the handlebars and nothing I went to the starter Solenoid and it’ll try to start but won’t turn over I’m getting no spark from the spark plug wires or anything I don’t know why the starter switch on the handlebars isn’t working it’s plugged in and hooked up to the brake handle please help
Have you checked the 30a main fuse? Good place to begin.
Check your 15 amps fuse for Ignition too, not only 30 amps for starter. Did you change out spark coils?? just wonder because My bike does the same thing when I ordered wrong coil (there are two kinds of spark coil, long coil for 2001 to 2004 VL800 and short coil for fuel injected) Short coils blew fuse and it won't start neither firing sparks. So I ordered correct coil (long coil) and finally I was able to fire up and run with no issue. So Check that one too..
