Everything was fine when put away for winter. Would not start in spring. It would fire with fuel shot into carb,. pulled carb put in new diaphragm and kit .Vacuum fuel pump I thought worked poorly. Temporarily used 1-2 psi electric to test. Now fires and runs with new plugs Old plugs looked fine but changed for good measure.. However.... Idles ok revs up with a little missing. If I opened up it starts to choke out. When shut off after short idle, rear cylinder backfires with a bit of a flame. Possible tight exhaust valve? Any ideas appreciated.....
