Looked through your threads. Seems you were able to fit the stock 05 cables on 16" apes?Try to re route them.Look at my older posts amd pics. Maybe you can save some cash.
How did your order go? Getting ready to install some soon as well.I just went ahead and ordered all new cables and hose. Needed new ones anyway. Ill let you guys know how it work. Hopefully I ordered the right stuff. If it does ill post the sources.
Use the vendor one of the guys posted earlier here. You need to measure the required length for the pull/push throttle cables. 6+ was a bit too long. They get stiff if they are folded too tight. luckily I had raised the tank to add a more aggressive look and had a bit of space under it to tuck the excess. The 6+ on the clutch was perfect and the so did the 6+ on the brake hose. I ordered these cables from eBay. Also, I had to add an aluminum plate for the cable connections on the throttle hand control box. I'll post some pics later.How did your order go? Getting ready to install some soon as well.
