I have an 05 C50 with 6100 miles. This morning when idling it just stopped running. I starting it back up no problem but when I give it throttle and hold it 1/3 open (in neutral), it sounds good for 1 sec and then sounds like somebody hits the kill switch for 1/2 sec then back to good...it will continue to do this for as long a I hold the throttle open. It does this no matter much throttle I give it.
I tried adding some good fuel, not change.
Will a bad plug cause this (almost like it is running one 1 cyl?
Any help with be appreciated.
Thanks
Wait for Skrapiron to chime in.
Him and others will at least get you pointed in the right direction.
Hangeth thou in there.
I'll point out the obvious... 600 miles per year for 9 years may indicate old gas, dirty injector, dirty air filter, original tires, original brake fluid, plugs, plug wires. etc.
