I appreciate that so much!! Thank you! And yes! Omg this bike has beenessed with badly! Went to rejet for the spike filter, and carb has missing gaskets, cracked peices. Stripped screws even.. But, today I went ahead n closed the AF screw quite a bit.. Helped.. But, I'm going to I stall new original air filter n see what happens. Just sucks, cause I just put brand new oil change and it's already fouled with fuel from being overly rich.. I really appreciate the feedback. Learning as I go. LolFirst thing is do a compression check on both cylinders. Service limit is 152psi. If either cylinder is less than that, you are in need of a rebuild. I also noticed you went from a uni-filter to a spike cone filter on the intake. Neither is stock, which means the previous owner monkeyed with the carb and jetting. If your compression checks out, then you will need to pull the carb and the jets, inspect and replace as needed.
Thank you! And it only has one carb. I replace main jet with dynojet kit. Adjusted the AF screw to a drastic different setting and it seemed to help. I'll be checking plugs and mialge this weekend, if still garbage, I have brand new original air cleaner ready.. I do appreciate the feed back. Thank you!Sweet looking bike Nice job. Did you get your carbs aligned right. Also with burning fuel I would check to make sure you have the right Jets installed other than that not really sure
And byw, that little filter was going to crankcase. This is the filter that was right on the carb, under the fuel tank suffocating for fresh air. That's why I tried the spike filterI appreciate that so much!! Thank you! And yes! Omg this bike has beenessed with badly! Went to rejet for the spike filter, and carb has missing gaskets, cracked peices. Stripped screws even.. But, today I went ahead n closed the AF screw quite a bit.. Helped.. But, I'm going to I stall new original air filter n see what happens. Just sucks, cause I just put brand new oil change and it's already fouled with fuel from being overly rich.. I really appreciate the feedback. Learning as I go. Lol
And I appreciate it! Whenever possible, I'll definitely give advice from things I've learned.. Always big on paying forward..Your welcome there is wealth of knowledge here not just posted for manuals but some very knowledgeable people that are always willing to help.
