1 - 3 of 3 Posts
I greased the rear hub changed oil adjusted rear shockes took covers off every thing looks good inside it don't slip when in gear just when I let off gas or hit front brake hard and front shocks go down it makes the grinding sound someone said maybe front shocks blown.what could grind there I already checked brakes not it
If your front end is diving under braking, then the forks are WORN OUT. You need to have them rebuilt, including new seals, oil and springs.
1 - 3 of 3 Posts
