1 - 10 of 10 Posts
I changed rear tire last night.went on drive now I got a grinding noise in mid to rear of bike anyone had this problem.
Sorry to hear about the noise.
Hopefully it's something minor.
Your tire is too big.
You forgot to fill it with air.
Your engine is out of oil.
Take your pick.
Did you check to make sure the wheel was spinning freely after you changed the tire?
Did you use a torque wrench when you tightened the rear bolt?
Did you buy a Suzuki?
Just noticed you said the grinding is mid-point back on the bike.
Any chance you removed the final drive when you replaced the tire? It's possible the shaft is not fully engaged in the U-Joint. The drive shaft has a spring in the final drive that would probably allow forced reassembly even if the drive shaft wasn't fully engaged in the u-joint up front.
Hello all from sunny land of the fee and home of the slave..I put new rear tire on my 06 c90,I pulled driveshaft out, now I see u-joint just floating in can get it all way back to and on drive gear but I can not get driveshaft to line up and stab it in! What's best way forward guys? Sorry if I'm posting wrong but it's only way I could figure out.. thanks.. peace/out
Use a broom handle to swing the coupler back in place, then slide the drive back in. It is a bit of a pain in the butt, but manageable.
1 - 10 of 10 Posts
