Idle mix adjustment screw. - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 3 (permalink) Old 08-14-2017, 08:15 PM Thread Starter
Powerman79's Avatar
Can anyone post a picture or link that works of the location of the idle mix adjustment screw (not the black knurled plastic knob) I can't seem to find anything about its location.
Is that knob all there is?
Powerman79 is offline
post #2 of 3 (permalink) Old 10-16-2019, 02:03 PM
Gobbler865's Avatar
Underside of carb. Is a brass plug with a small hole drilled into it. Drill opening slightly larger. Don’t drill too hard...just enough to get thru. Then use a coarse thread drywall screw and screw in there enough to act as a handle. Wiggle back and forth and there’s your fuel adjustment screw.
Gobbler865 is offline
post #3 of 3 (permalink) Old 10-16-2019, 02:05 PM
Gobbler865's Avatar
I should also add that it works easier to drop the bowl to give you more room.
