Rejetting Matrix - Page 3 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #21 of 68 (permalink) Old 10-12-2006, 06:42 PM
v0lusia's Avatar
Originally Posted by Lunchbucket
thanks volusia.
the pilot will give easier starts and warm ups? plus better response in the low range RPM??
i only drove it yesterday for 15min or so. it was 30's out and wanted to get home ASAP from my buddies where i did the work and put the pipes on so didn't get a good idea of how it ran.
i can get a pilot jet easy and since i "been in there" it shouldn't be too bad.
thanks
Lunchbucket
Yes....
per BriMan
The pilot controls idle, up to 1/3 throttle.
The needle controls 1/3 to 5/8 throttle
The main jet controls the rest
-Twisties give me happy pants
v0lusia is offline
post #22 of 68 (permalink) Old 05-12-2007, 08:24 AM
pac50t's Avatar
I run totally naked - no air box at all. I have a custom made Uni directly on the air intake. I have a C50, so I just plugged in the PC III. But, I'm trying to get some info for people who want to do the same to a carbed Volusia, and will need to re-jet. Check the thread below for more info, and any help/pointers is greatly appreciated.
Some people think that they know. But, they don't know enough to know that they don't know.
https://www.volusiariders.com/viewtopic.php?t=51362
http://www.facebook.com/album.php?ai...9&l=eeb1a3e8b5
pac50t is offline
post #23 of 68 (permalink) Old 05-29-2007, 06:40 PM
canuckrider's Avatar
Marked for future reference!
"Sun on my face, wind in my hair, sound of my bike in my ears and peace in my soul..."
VR WESCALERO CHARTER MEMBER
canuckrider is offline
post #24 of 68 (permalink) Old 07-24-2007, 02:02 AM
crochammer's Avatar
I dropped to a 35 pilot jet from a 37.5. I am closer to sea level but did dial it all in using dyno runs.
If I wanted a Harley I would have bought one....son!
VR Wescalero Co-Founder and Charter Member
2006 Black Nomad Full Dresser
crochammer is offline
post #25 of 68 (permalink) Old 08-30-2007, 07:53 AM
isobig's Avatar
Went completely nekkid last year, used the matrix as a starting point.
2001 Vol. Used a 35 pilot jet and the DJ 150 main jet, DJ needle on 3rd notch as directed in the DJ instructions, mix screw out 3 turns, UNI Filter and depaired, debaffled & demickeyed mufflers. Ran slightly better than stock setup, but would bog down a little at full throttle. Would pull harder when throttle was reduced a bit indicating a bigger main jet was needed. Also suspected the pilot needed to be larger since it would still take a while before I could push the choke in and have it idle at proper rpm. Would also be a pain in the winter time at or just above idle unless I kept the choke out some.
My rides are mostly between 500' - 1500' above sea level.
Almost 2 weeks ago I put in a 40 pilot jet and the DJ 155 main jet, didn't touch the mix screw or needle. It made a nice difference! No more bogging down at full throttle and can push the choke in sooner after start up. This should also allow it to run better in the winter when I take it out for a spin in 30F weather.
Now I will have to watch and see how much it hurts the gas mileage.
'01 VL800 Red/Blk - totalled 6/17/2012
isobig is offline
post #26 of 68 (permalink) Old 09-05-2007, 11:13 AM
Jetting fix
OK r.e. jet sizes- if Mukuni runs about 10 smaller than Dyno for equiv. sizing according to the "matrix", does that mean that a 37.5 Dyno pilot equates t oa 27.5 Mikuni pilot? I run stock pipes, K&N in the airbox, and rejetted to a 140main/35pilot Mikuni sizes, and it still needs 1/3 choke to roll on w/o stumbling. Above 1/2 throttle it pulls well. Vibrates a lot now, too, and backfires a lot. Mechanic also adjusted the fuel pump rather than the shims and raised needle, as it reportedly didn't run well. Could it be that I need a much smaller pilot?
"The first rule of intelligent tinkering is to keep all of the pieces"- ALdo Leopold
2ndlife is offline
post #27 of 68 (permalink) Old 09-12-2007, 02:31 PM
isobig's Avatar
Re: Jetting fix
I could be wrong but I have not seen any pilot jets made by Dyno. I believe all the references to pilot jets are Mikuni's.
If you need the choke that is a key symptom that it is too lean. The choke richens the mixture. Have you adjusted the idle mixture screw after rejet?
Don't know of any fuel pump on a carb Vol so I don't know where the mechanic got that from.
isobig is offline
post #28 of 68 (permalink) Old 10-03-2007, 10:13 PM
Mechanic said he adjusted the "fuel accelerator pump'', which I had not heard of either... I have not adjusted the screw again after rejetting- that could be it. I did before, (first mod, actaully) but otherwise just told him to set it at 2 3/4 turns. I'll try it and see.
Thanks!
Work sure cuts into riding time when the days turn short....
2ndlife
2ndlife is offline
post #29 of 68 (permalink) Old 01-23-2008, 09:30 AM
03Volusia40th's Avatar
What Is Pilot Jet Part Number?
I need to order either a 37.5 or 40 pilot jet for my 03 Vol. I have the K&N carb mount filter, and Cobra Drags. Just got the Dynajet 3195 kit, was gonna go with their 155 main recomendation but want to get a pilot jet also.
I can't find the exact pilot jet to order, part number, or where to order.
Can anyone help?
Thanks.
03Volusia40th is offline
post #30 of 68 (permalink) Old 01-31-2008, 08:50 PM
PhilJet's Avatar
Re: What Is Pilot Jet Part Number?
Can anyone help?
Thanks.
www.motorcyclecarbs.com
"Don't take yourself so seriously, no one else does."
"This life's hard, man, but it's harder if you're stupid."
You can't learn anything while you're talking.
'01 Black & Red Volusia - sold
'09 Black FJR
'16 Ural Gear Up
'73 Yamaha CT3
'83 Honda XL250R
PhilJet is offline
