Front caliper seized, how to rebuild master cylinder? - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 5Likes
post #1 of 18 (permalink) Old 09-25-2019, 10:46 AM Thread Starter
I had the caliper rebuilt by a shop recently and the front brake was working fine until yesterday when it seized up again. Shop says the master cylinder needs to be rebuilt now so I bought a rebuild kit and plan on doing it myself.
I've seen a few YouTube videos on other bikes and it seems pretty straight-forward but I was wondering if anyone had any other tips or resources they use to rebuild one for a '91 Intruder 750, thanks all.
KennyFSU is offline
post #2 of 18 (permalink) Old 09-26-2019, 01:17 PM
Master cylinders are generally very easy to rebuild. Remove the lever and the dust boot. Sometimes there is a spacer, sometimes the lever pushes right on the piston. Look in the bore and you'll most likely see a snap ring. Remove that and the piston will come out, install the new one, re-assemble.
Now when you're talking a bike that's pushing 30 years old corrosion can be a major issue especially if brake fluid was neglected for decades as it often is. Once you get it apart inspect the inside of the piston bore for pitting/corrosion. Light amounts can be cleaned up by just shoving a bit of scotch-brite pad in there and spinning it around, but if the new piston still does not slide in smoothly/freely, you probably should replace the M/C.
KennyFSU likes this.
RWhitehosue is offline
post #3 of 18 (permalink) Old 09-27-2019, 11:50 AM Thread Starter
Thanks for the tips.
The front brake seems to work fine when left alone to cool down. After riding it for a few minutes and getting it warmed up it will seize on me again, any ideas??
KennyFSU is offline
post #4 of 18 (permalink) Old 09-27-2019, 01:55 PM
Gene's Avatar
Hi Kenny. Welcome to the VR from snowy Alberta Canada. Yes, Iím looking out the front window and watching the snow fall.
As to your hydraulic brake problem, the fact that the lockup occurs after the brakes warm up indicates a strong likelihood that expanding brake fluid is doing the lock up for you.
The fluid will naturally expand when ir warms but there is a feature in the master cylinder that is supposed to allow the expanded fluid back to the cylinder so there is something that is preventing that from happening.
1. In the bottom of the master cylinder reservoir are two holes. One large and one small.
The large hole is behind the piston to refill the pumping chamber in front of the piston cup when you pump the lever. (You can ask how that happens later). The small hole is in front of the piston - on the caliper side- to allow the fluid to return to the reservoir when you release the brake lever and also as the fluid expands.
2. The second possible cause occurs inside the brake hose when the hose deteriorates due to age of the system. The lining of the hose acts as a one way valve to hold the fluid in the caliper.
I would check the master cylinder reservoir first.
Two things are the major causes of the problem in this location.
1. Debris in the bottom of the reservoir that gets stuck in the little hole - and by little, Iím talking 0.010Ē -
2. The mispositioning of the piston in its resting position. When the brake is released the piston Normally sits between the two holes. If the piston is forced to sit slightly in front of the hole, fluid canít return.
a. Corrosion in the cylinder or dirt behind the piston.
b. The push rod between the lever and the piston is not in its proper place due to a reassembly problem at some time in the past.
Hope this gives you some results because this is all that comes to mind.
duglaura and KennyFSU like this.
06 C50C (Special Edition)
CYFHMN member ---
Gene is offline
post #5 of 18 (permalink) Old 09-30-2019, 09:34 AM Thread Starter
Hello from Florida,
What's this "snow" you speak of?? Lol.
Thanks for the insight. Yesterday I removed the MC cap and slowly squeezed the brake lever, no fluid squirted up from the MC at all, does this mean I have debris in the holes? The fluid looked good (was bled about a month ago) and I could not see anything clogging the holes.
It's having the same issue, caliper stays clamped and won't release until several hours later. I have a MC rebuild kit on order but I'm hoping it's a simpler fix.
KennyFSU is offline
post #6 of 18 (permalink) Old 09-30-2019, 12:09 PM
Gene's Avatar
Hello from Florida,
Yup. Got about 6Ē of the whit stuff. Good thing is it will melt away over the next week. Bad thing is the grain harvest is less than half dome around here. SIL stil has over 2000 acres to do.
There should at least be a swirl in the reservoir when you pull the lever. - if not an out right spirt of fluid flying up.
Something is blocking that little port.
CYFHMN member ---
Gene is offline
post #7 of 18 (permalink) Old 10-01-2019, 05:13 PM Thread Starter
I only see one hole and I used a small pointy object to clean it out but there was nothing clogging it. Where is the other hole located? Is it under a flap?
Previous: '01 Gixxer 600
Current: '91 Intruder 750
KennyFSU is offline
post #8 of 18 (permalink) Old 10-02-2019, 02:47 PM
Gene's Avatar
The large hole is the one for refilling the pumping chamber when pumping the brakes especially when bleeding air from the system or if there is excessive pad/shoe travel and adjustment is needed.
It looks like the “return hole” has a valve of some sort -that is not a usual design. There could be a problem wit that valv/return.
If you get is so it is rideable again and the brake seizes up again just loosen the hose fitting on the master cylinder. If the brake releases, the problem is in the m/cylinder.
If it doesn’t release then, loosen the caliper fitting. That will tell you about the hos.
No release with caliper hose loosened, means something wron with the caliper.
htlong likes this.
CYFHMN member ---
Gene is offline
post #9 of 18 (permalink) Old 10-05-2019, 11:21 AM Thread Starter
Just rebuilt the MC, brand new brake line, and fresh dot3.
Only issue now is I can’t seem to bleed the brakes. Opened the mc cap, put a clear tube on the caliper nipple, several squeezes of the lever, hold, loosen nipple and allow fluid and air to escape. Repeated this process several times and not much air escaped and the lever still has no resistance.
I even bled the mc by removing the banjo bolt and placing my finger over the hold and pumped the lever.
Any ideas?
KennyFSU is offline
post #10 of 18 (permalink) Old 10-05-2019, 03:09 PM
Gene's Avatar
Only issue now is I canít seem to bleed the brakes. Opened the mc cap, put a clear tube on the caliper nipple, several squeezes of the lever, hold, loosen nipple and allow fluid and air to escape. Repeated this process several times and not much air escaped and the lever still has no resistance.
Any ideas?
After rebuilding the MC it is much easier to bleed the rest of the brakes if you bleed the MC before installing it on the handlebars. That way you make sure that the cylinder is level and no air is trapped in a high spot.
You can also reverse bleed by forcing brake fluid in through the bleed screw and out the cylinder reservoir. In that case make sure that the cylinder is as level as possible.
Bleeding these brakes can be a bit frustrating at times.
CYFHMN member ---
Gene is offline
