Slipping Clutch - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 7 (permalink) Old 09-18-2019, 10:03 AM Thread Starter
Jmbrad's Avatar
Slipping Clutch
Changed my oil a couple weeks ago and now have a slipping clutch. I did change brands of oil from Castrol 4T to Valvoline 4 Stroke ATV oil. Should have stuck with the Castrol I guess.
Here's what I used
Valvoline ATV Oil
Says it's OK for Wet clutch.
It's been a while since I adjusted the clutch, will try that this evening.
Any other suggestions?
2011 Vulcan Nomad 1700 (SOLD)
New to me 8/22/15 w/7k miles
03 Vol 1st Bike EVER!
New to me in 8/11 w/
16k miles
Jmbrad is offline
post #2 of 7 (permalink) Old 09-18-2019, 10:11 AM
I would just change the oil back to Castrol.
KennyFSU is offline
post #3 of 7 (permalink) Old 09-18-2019, 12:50 PM
The change shouldn't have caused the slippage. It's probably more likely to be time for a full adjustment. There's a sticky on doing a complete clutch adjustment.
The Following User Says Thank You to scorpion46 For This Useful Post:
Jmbrad (09-18-2019)
post #4 of 7 (permalink) Old 09-19-2019, 08:17 AM Thread Starter
Jmbrad's Avatar
Did the adjustment last night. No change.
Last time I had to adjust the clutch, I could tell a difference. That was over 6 years and 20k miles ago.
I guess it's time to shop for a clutch rebuild kit.
16k miles
Jmbrad is offline
post #5 of 7 (permalink) Old 09-19-2019, 10:30 AM Thread Starter
Jmbrad's Avatar
On the gasket, which one do I need?
11482-41F00
or
11482-44110
Is the latter maybe a replacement (newer) part number?
Thanks,
Jody
16k miles
Jmbrad is offline
post #6 of 7 (permalink) Old 09-19-2019, 12:28 PM Thread Starter
Jmbrad's Avatar
Nevermind, it's the first one. Found it on eBay for 10.50 shipped.
16k miles
Jmbrad is offline
post #7 of 7 (permalink) Old 09-19-2019, 12:51 PM
I've found numerous "wet clutch" oils that caused clutch slippage almost immediately, especially on bikes that have a pretty marginal clutch to start with. The couple times I tried Mobil 1 motorcycle oil it has universally caused the clutch to feel mushy and usually slip in top gear. On my Vmax it screwed up the one way starter clutch, about half the time it'd just freewheel. Switched back to rotella and the problem vanished.
I found on my 05 the clutch was a little mushy and I could make it slip flooring it in top gear even after adjusting it. The previous owner made a big stink about how he only ever used mobil 1. Hmmm. Drained that out put conventional Rotella in, and whaddya know the clutch slippage went away, and it's been about 10k miles since and no signs of it returning. Bike has about 25k on it now.
RWhitehosue is offline
