Question on rear wheel - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 5Likes
  • 2 Post By scorpion46
  • 2 Post By Duffy
  • 1 Post By Psyc0
post #1 of 9 (permalink) Old 08-03-2019, 04:36 PM Thread Starter
Hate to admit this, but ...
I've had a Volusia or a C50 since 2004, and never noticed this before - went for a 50 mile ride with my better half, and when I got home, I decided to check the tire pressures. In doing so, I noticed that the rear wheel hub was pretty warm - I didn't want to leave my hand on it for more that a couple of seconds. Both the brake drum and the rear differential were warm. I thought that I had plenty of play in my rear brake linkage, so I don't believe that was a factor. Question: is it normal for the rear hub assembly to get pretty warm, and if not, what are some possible issues?
Thanks for any help!
buckeye4990 is offline
post #2 of 9 (permalink) Old 08-03-2019, 04:52 PM
When you ride 2 up, it changes the dynamics of the rear brake over riding solo. Your brake was dragging.
the_snake1201 and htlong like this.
scorpion46 is online now
post #3 of 9 (permalink) Old 08-03-2019, 06:05 PM
Gene's Avatar
The brake may have been dragging but it is normal for the final drive to run 50 to 100 degrees above ambient temperatures.
06 C50C (Special Edition)
CYFHMN member ---
Gene is offline
post #4 of 9 (permalink) Old 08-04-2019, 11:55 AM Thread Starter
That's good to know. Even riding with 2-up, I have a good two inches of brake pedal travel before it engages. I was hoping that I didn't have to back it off any more.
post #5 of 9 (permalink) Old 08-04-2019, 05:15 PM
Duffy's Avatar
You might check your diff oil level also.....
htlong and scorpion46 like this.
Wescalero Charter Member
Duffy is offline
post #6 of 9 (permalink) Old 08-04-2019, 05:56 PM Thread Starter
Good suggestion. That's an easily-overlooked maintenance item.
Fortunately, it was full up to the top plug and in checking my records, was changed in 2018.
post #7 of 9 (permalink) Old 08-05-2019, 09:46 AM
htlong's Avatar
what weight oil does the diff. take ? I have 2 bottles that are different weights and yes I OVERLOOKED that last oil change whooops
htlong is offline
post #8 of 9 (permalink) Old 08-05-2019, 12:10 PM
I use 80W-90.
Duffy likes this.
The Following User Says Thank You to Psyc0 For This Useful Post:
htlong (08-06-2019)
post #9 of 9 (permalink) Old 08-05-2019, 08:22 PM
The hypoid gear generates a fair amount of heat when in use. Completely normal for it to be warm to hot after a ride especially after the additional load of riding 2up. 75-90 or 80-90 are fine, it's not terribly critical.
If you have 2" of play in the pedal that's more than enough to ensure suspension travel isn't binding things up.
RWhitehosue is offline
The Following User Says Thank You to RWhitehosue For This Useful Post:
buckeye4990 (08-08-2019)
