Backfiring and detonation problem - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 18 (permalink) Old 07-19-2019, 07:49 AM Thread Starter
Strelok's Avatar
Hello all! Sorry for my grammar(
I have a 2008 Boulevard c50, and for almoust half a year I have a problem with detonation and backfiring. It starts only when the bike is hot, when you try to accelerate fast from low RPMs, you can hear detonation sound from the engine, also sometimes you can hear a pop from the exaust pipe when you ride on middle RPM with no trottle. My pipes and tail light are covered with black soot. I tryed to change the petrol, changed the sparks, air filter, TPS sensor, 3 times I cleaned the injectors, cleaned fuel filters and everything inside my tank. I've tryed octane boosters and fuel injector cleaners, but nothing seems to help. I live in Vietnam, we dont have any qualified mechanics here, so I do it by myself, learning step by step. May be someone can help me? Where to look? What else to check?
Strelok is offline
post #2 of 18 (permalink) Old 07-19-2019, 08:36 AM
Try the pair valve disconnect, or removal if proven defective. Suzuki C50 and Volusia are nearly the same set-up.
Volusia Pairvalectomy
post #3 of 18 (permalink) Old 07-19-2019, 11:56 PM Thread Starter
Strelok's Avatar
Thank you! Can you tell me, why it should help? Why people do this?
Strelok is offline
post #4 of 18 (permalink) Old 07-20-2019, 04:05 AM Thread Starter
Strelok's Avatar
On my bike it is different
https://www.impex-jp.com/catalogs/mo...ir-209538.html
no connection to the fuel system
Strelok is offline
post #5 of 18 (permalink) Old 07-20-2019, 08:47 AM
The pair valve is an anti-pollution/emissions device, which frequently goes bad, causing symptoms very similar to those You are experiencing.
post #6 of 18 (permalink) Old 07-20-2019, 02:33 PM
Greetings from Indiana. Glad you're here.
post #7 of 18 (permalink) Old 07-21-2019, 01:21 AM Thread Starter
Strelok's Avatar
Did it today in the morning. No change, stiil same problems
Strelok is offline
post #8 of 18 (permalink) Old 07-21-2019, 08:33 AM
Have the valves been adjusted recently?
post #9 of 18 (permalink) Old 07-21-2019, 09:08 AM Thread Starter
Strelok's Avatar
Yes, We did it like in manual. Things got worse after that I think... I have a lot of rust in my tank, I will try to clean it on this week
Strelok is offline
post #10 of 18 (permalink) Old 07-21-2019, 02:02 PM
Did You only turn the crankshaft counter-clockwise, or did You use clockwise motion, when performing the valve adjustment?
