Backfiring and detonation problem - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #11 of 18 (permalink) Old 07-21-2019, 11:19 PM Thread Starter
Strelok's Avatar
Originally Posted by Psyc0 View Post
Did You only turn the crankshaft counter-clockwise, or did You use clockwise motion, when performing the valve adjustment?
counter-clockwise only as I remember
Strelok is offline
post #12 of 18 (permalink) Old 07-22-2019, 08:03 AM
Next question:
Did You make certain to adjust the front & rear valves on the correct crankshaft rotations?
post #13 of 18 (permalink) Old 07-22-2019, 09:54 AM Thread Starter
Strelok's Avatar
Next question:
Yes
Strelok is offline
post #14 of 18 (permalink) Old 07-22-2019, 12:46 PM
The machine starts/runs, but runs poorly, with backfiring and detonation.
More likely a fuel issue, because an extremely lean fuel condition will cause the problems that You are experiencing.
If the ignition/spark was the issue, the machine would probably not run at all.
post #15 of 18 (permalink) Old 07-23-2019, 11:48 PM Thread Starter
Strelok's Avatar
The main question if it is like this, why it starts only when it is hot?
Strelok is offline
post #16 of 18 (permalink) Old 07-25-2019, 11:31 PM
I had a problem with backfiring a few years ago and I believe all I did was install a new air filter. The backfiring only happened for me when the engine was warm. I have a 2003 with carbs instead of fuel injection, so it may be different.
Volkeno is offline
post #17 of 18 (permalink) Old 08-01-2019, 04:40 AM Thread Starter
Strelok's Avatar
I cleaned all the fuel system again, cleaned the tank and filter, installed new injectors, performance is better, but still same problems, sometimes it backfires on low trottle, has detonation. And sometimes it keeps the engine on high rpm on neutral, like it is cold, but it is not. Any thoughts?
Strelok is offline
post #18 of 18 (permalink) Old 08-07-2019, 08:56 AM Thread Starter
Strelok's Avatar
re-tuned STPS and TPS sensors, backfiring almost gone, but detonation is still here
Strelok is offline
