08 M50 doesn't idle up cold and stalls before warm-up - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 5Likes
post #11 of 27 (permalink) Old 07-19-2019, 10:47 AM
Originally Posted by scorpion46 View Post
Ace Hardware usually has an exact match for my bolts, in chrome or stainless.
They have chrome bolts? My local big box hardware store only has stainless, zinc plated, or galvanized. I should start going to Ace.
ipartola is offline
post #12 of 27 (permalink) Old 07-19-2019, 11:25 AM
DickB's Avatar
Not all Ace Hardware stores carry them. Mine doesn't.
On My M50 that screw is a wide button socket head screw with a shoulder, similar to the attached photo. Pretty specialized. If your Ace carries this, fantastic!
2006 blue M50
2019 Honda Super Cub C125
1983 Wetbike (sold)
DickB is offline
post #13 of 27 (permalink) Old 07-19-2019, 04:10 PM
Oh! That 1! You had to loose THAT 1!
Been lucky or not so much throughout life?
post #14 of 27 (permalink) Old 07-19-2019, 07:33 PM
I don't believe that the shoulder is a requirement. A
post #15 of 27 (permalink) Old 07-20-2019, 09:13 AM
DickB's Avatar
The holes on the chrome cover are oversize - much larger diameter than the screw threads. The shoulder is larger diameter and fits the larger hole. You would not get a good fit with just a standard screw.
2006 blue M50
1983 Wetbike (sold)
DickB is offline
post #16 of 27 (permalink) Old 08-10-2019, 08:34 PM Thread Starter
Originally Posted by RWhitehosue View Post
The idle air control is on the left side of the engine behind a little decorative cover. It's just a plunger that a servo can move in and out to open/close a valve, respectively. Sometimes they get stuck. There's two bolts that hold the servo in, when I removed it on mine the bolts were VERY tight and Suzuki makes all their fasteners out of cheese, so very easy to strip. Ensure the plunger moves freely and spray some carb cleaner in there to remove any gunk. With the servo out, turn the key on with kill switch on, then turn it off. The plunger should suck out (open) for cold starting. When you turn the key off it should release (closed).
It's just an air valve that allows more air to bypass the throttle blades, effectively giving the bike more throttle. Older EFI bikes with a "choke" lever did this, it just was a little cam that propped the throttle open slightly more than usual.
I'm referencing a 2005 model, but to my knowledge these things did not change too much over the years.
Took me a while to check some things out, but not quite everything yet.
Was able to remove the servo, but when I test it with key on and flipping the cut off switch on off does nothing, it never moves. Also for now I don't know where the other end of electrical connector is (somewhere under gas tank, I know), but not sure if I can reach it to unplug easily or not.
I tried moving the metal shaft (what the plunger pushes I think) with fingers, it has some free play, but doesn't move much at all? It all looked very clean by the way.
Even tried ordering a new second air valve assembly, but guess what, every Suzuki parts online dealer (including partzilla and revzilla) in US is out of stock ? ... may say available, but once you purchase it will get backordered with unknown ETA, fantastic.
EDIT: Just checked ebay and found a shop parting out bikes, grabbed a repalcement valve with servo for $10 shipped, will swap and test once I get it.
Otherwise I guess at this point I should just remove the whole valve assembly and take it apart completely, clean with carb cleaner and put back in.
OK great, sounds like a plan, but what if servo-motor is dead? Need to check it again on completely cold bike to make sure... I think the root cause of problem here is that servo not doing its job at all ... I literally heard my bike only once since I got it in early July, when it was trying to rev up on its own when started cold and never did it again LOL
'08 Suzuki Boulevard M50 @ 9,220 miles [STOLEN]
feniks is offline
post #17 of 27 (permalink) Old 08-16-2019, 03:23 PM Thread Starter
damn, swapped the whole Second Air valve with a shiny looking replacement (part out), zero difference, still shuts off instantly when started cold unless I roll on the throttle a bit and hold it there for a minute ... which brings me to conclusion that something else affects actuating that servo-motor within the valve ... I guess I will be checking ECT sensor next time.
I might also try running seafoam through gas tank to cleanup fuel injectors while at it and hope it improves anything.
Annoying issue to get this bike running from cold start, especially in colder weather...
feniks is offline
post #18 of 27 (permalink) Old 08-16-2019, 03:53 PM
Sounds like a throttle lock cruise control would be your easiest fix. It would serve double duty plus you need one to enhance your riding experience. It makes it easier to text and ride as well. No need to tie up your right hand while blasting down the highway at Mach 4.
post #19 of 27 (permalink) Old 08-16-2019, 04:27 PM Thread Starter
that would be a workaround, but still a cool one hehe
I'd like to fix the root cause if possible ... but from the lack of other ideas will try seafom additive in fuel, check plugs when I have chance and check the coolant temp sensor resistance while at it ... perhaps it provides wrong temperature input to computer so the fast idle never gets engaged, because it "thinks" it is always warmed up even when cold as stone? ... may take me a while to pull up the tank as I have never attempted it yet and check that stuff one day LOL
I heard those bikes also have a secondary Throttle Position sensor too used by the automatic fast idle (which doesn't work for me at all)?
feniks is offline
post #20 of 27 (permalink) Old 08-27-2019, 02:55 PM Thread Starter
found the problem, well .. not exactly, but I think it's in the gas tank (moisture in fuel) or fuel system dirty
The other day when I was around 40 miles north of city experienced issues re-starting the warm bike and idle was really low and stuttering, so stopped by local Autozone and picked up the can of Seafoam, dumped it into a half full gas tank, problem solved.
Refueled the tank after coming back home, next time I started the bike in morning at 7:30am, it properly did a quick fast idle sequence and stayed idling on its own for the whole duration while in Neutral, I never had to touch the throttle.
Did it stay perfect forever? No, few days later it happened again, not sure yet if permanently, but I know now what it is related to.
I am thinking, I may need to run seafom or some other fuel stabilizer with gentle cleaning agents a few more times to clean out whatever the residual issue might be, it's probably either moisture/water in gas tank or dirty injectors, etc.
still haven't gotten around to checking spark plugs yet LOL ... was looking for a gas tank prop, finally found something that should do... but no time to touch it yet ...
feniks is offline
