Speedo jumping around - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 15 (permalink) Old 06-25-2019, 03:23 PM Thread Starter
So this is a weird one. I noticed that sometimes my speedometer randomly jumps up to a much higher speed than I am actually going. Like, I am going about 20-30, and it suddenly jumps to 50-60, then back down to what I am actually doing. It happens very briefly and intermittently. Is this more likely to be an electrical problem, or a problem with the hub speed sensor? In a month or two I am going to replace the tires on this thing, so I'll be taking both wheels off then. Should I just order a replacement sensor before then and swap it anyways? Or should I start looking for electrical gremlins now?
ipartola is offline
post #2 of 15 (permalink) Old 06-25-2019, 05:28 PM
v0lusia's Avatar
Yes it sounds like the magnet sensor in the front wheel. Be careful because they are different on the Volusia VS C50. If you search you should find posts here which contain the correct part numbers and hints
-Twisties give me happy pants
v0lusia is offline
post #3 of 15 (permalink) Old 06-25-2019, 07:10 PM
Whiskey's Avatar
I hate it when my speedo jumps around!
I'd agree that it's probably the sensor in the front wheel.
2005 Boulevard M50 (DOA)
2006 Boulevard C50 (retired)
2000 BMW R1100RT
2017 KTM Duke 390
Whiskey is online now
post #4 of 15 (permalink) Old 06-25-2019, 08:28 PM Thread Starter
Whiskey, how did you get that video of me? Haha
Is it ok to let this go for a month or two or should I be taking care of this ASAP? Is it a safety issue or just a convenience one?
ipartola is offline
post #5 of 15 (permalink) Old 06-25-2019, 09:45 PM
Whiskey's Avatar
It's only a safety issue if not knowing how fast your going will endanger you. Personally I never looked at the speedometer on my C50 since it's basically sitting in your lap. The only other downside I can think of is if you use the tripmeter to figure out how much gas you have left. I think the wheel sensor is used for it. I could be wrong on that.
2000 BMW R1100RT
2017 KTM Duke 390
post #6 of 15 (permalink) Old 06-25-2019, 11:13 PM Thread Starter
Yeah I do use the trip meter, the fuel gauge is always blinking empty. I am not inclined to fix that since I read that they are very inaccurate anyways. Currently it only jumps around a little bit and then settles, so I think for now it’s ok. I guess I’ll wait until I go for the new tires or if it gets really bad. Thanks!
ipartola is offline
post #7 of 15 (permalink) Old 06-26-2019, 05:40 AM
Whiskey's Avatar
The fuel gauge is always flashing empty? There's a good chance the two are related if that's the case. Could be the instrument cluster itself going bad.
2000 BMW R1100RT
2017 KTM Duke 390
post #8 of 15 (permalink) Old 06-26-2019, 11:05 AM Thread Starter
Could be. Though the fuel gauge was always a thing, while the speedo jumping started only recently. Could be a loose connection I guess.
ipartola is offline
post #9 of 15 (permalink) Old 06-26-2019, 11:56 AM
PapaBean's Avatar
I had that issue when my ground wire was cracked. Replaced the ground cable, soldered a new connector onto it, reattached to frame and all was good!
PapaBean is offline
post #10 of 15 (permalink) Old 06-26-2019, 12:11 PM Thread Starter
Which ground wire was that?
ipartola is offline
