Fuel pump or injectors need cleaned, instructions??? - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 7 (permalink) Old 06-09-2019, 12:26 PM Thread Starter
Notalentbum's Avatar
My wife’s C50T has sat a couple years. I’m guessing either the fuel pump or the injectors are plugged up with congealed gas. If I spray starting fluid in the air cleaner it will start and run as long as I spray. I have not worked on this bike at all so looking for some insight on how to get this repaired. The bike is currently in a storage unit but I’ll be bringing it to the house Wednesday afternoon where I can work on it.
Thanks for any assistance you can offer.
Matt
'09 Kawasaki Concours
'11 Suzuki C50T
'98 DR-350 for playing in the dirt
'03 Honda CBR600RR track bike
Notalentbum is offline
post #2 of 7 (permalink) Old 06-09-2019, 01:16 PM
Drain and remove the tank. Remove the fuel pump and inspect all of the filters, screens and impeller. Remove the fuel injectors and have them pressure tested. If needed, have them professionally cleaned. Replace all of the fuel hoses and reassemble .
No amount of "mechanic in a bottle" will get it to run right if there is sludge on the fuel system.
Skrapiron is online now
post #3 of 7 (permalink) Old 06-10-2019, 06:50 AM Thread Starter
Thanks! I knew all that FI cleaner crap they sell in the stores is nothing but snake oil!
I guess I better find me a repair manual for the bike.
'11 Suzuki C50T
post #4 of 7 (permalink) Old 06-10-2019, 07:20 AM
If there was untreated fuel left in the tank for "years", then there is a very high likelihood that there will be rust in the tank as well. The alcohol in gas attracts and holds atmospheric moisture, which will kill the insides of your tank and components. So don't be surprised if you're greeted with red, scaly caner when you open it up.
post #5 of 7 (permalink) Old 06-10-2019, 07:41 AM Thread Starter
Hadn’t thought of that! It was put in storage in early December of 2017 after our house fire. I tried last July to get it out but that’s when I found it wouldn’t run. Kinda wrote it off for the year at that point. Thought I’d try to get it running now so it’ll be good to go once we move back into our rebuilt home, hopefully next month.
Matt
'11 Suzuki C50T
post #6 of 7 (permalink) Old 06-26-2019, 08:26 PM Thread Starter
Finally all better! Explanation in my other Help! thread.
Thanks, Matt
'11 Suzuki C50T
post #7 of 7 (permalink) Old 06-26-2019, 11:22 PM
Fuel injector cleaning additives do work -- but you can't expect miracles on a bike that's been sitting for years. Using the cleaners regularly works to keep things clean, and fuel stabilizers/cleaners like Sea Foam will help tremendously to prevent sludge forming in bikes that sit for weeks or months -- like through the winter months.
oldenslow is offline
