Sticky Shifter with miles to go - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 7Likes
post #1 of 19 (permalink) Old 06-04-2019, 06:08 PM Thread Starter
Menhir's Avatar
This came up all at once and nothing first...
As I rode off to work this afternoon the shifter became sluggish to the point where I had to use several firm attempts to downshift, especially but not exclusively, into first gear.
Also, up-shifting was troublesome and a couple of times I couldn't get into fifth gear (luckily not during the highway portion on the trip).
Here's where it's really weird: When I couldn't get into 5th after several attempts I tried the heel shifter and it wouldn't move at all...as if it had bottomed out.
I can't see anything physically jamming the shifter.
it doesn't drop out of gear and it's not making any unusual noises either.
Any ideas?
At this point, I'm pretty sure I can make my 30 mile mostly interstate nightime commute home, but I'd like to get an idea what the deal is.
All ears now.
Pray, Hope, and Don't Worry.
Menhir is offline
post #2 of 19 (permalink) Old 06-04-2019, 06:27 PM
chromedome1954's Avatar
Got any WD40 with ya?
I spray my shifter linkage several times a season and I can feel the difference
it makes.
Menhir likes this.
chromedome1954 is offline
post #3 of 19 (permalink) Old 06-04-2019, 07:06 PM
i am not trying to be cute...please define specifically what you mean by "shifter linkage"...thank you
fokkerdr3ww1 is offline
post #4 of 19 (permalink) Old 06-04-2019, 07:17 PM
Have you done any work around or to the shifter linkage lately...i bought pretty chrome toe and heal shifter pads for my 09 C50 and as i rode off into the sunset i could not shift out of 2nd...back home i noticed that all looked good on the surface but....as i manually activated the shifter i noticed that the clearance was gone from the heal part and it was catching on the floor board.... i had to use the adjustment nuts on the shifter rod to get back the clearance needed to prevent the jam at the back of the board....now i have plenty of clearance and the shifting is as smooth as silk....i hope this may help you
post #5 of 19 (permalink) Old 06-04-2019, 07:54 PM
Any pivot points involved with the shifter and linkage.
Do you go by a store that might sell WD40 on the way home?
post #6 of 19 (permalink) Old 06-04-2019, 07:55 PM Thread Starter
Menhir's Avatar
Looking for some WD40. 🙂
The only work I did recently was to change the oil and filter. That was a few weeks ago. Mobil 1 15W50.
Other than that, just some odds and end.
Menhir is offline
post #7 of 19 (permalink) Old 06-04-2019, 09:16 PM Thread Starter
Menhir's Avatar
Ya know...I have four cans of WD40 at home....Where I ain't.
I guess I better add that little item to my saddlebag tool kit.
It's always what you don't have that you need.
There's a hardware store nearby.
Menhir is offline
post #8 of 19 (permalink) Old 06-04-2019, 09:55 PM
Good luck!
Menhir likes this.
post #9 of 19 (permalink) Old 06-04-2019, 11:00 PM Thread Starter
Menhir's Avatar
Home safe.
It shifted a bit better on the way back but it's still a bit gummy. At least I hit every gear I wanted, even if it somtimes required a bit of persistence.
I'll apply the WD40 tomorrow in the daylight and hopefully that'll do the trick.
Thanks all. 🙂
Rob 61 likes this.
Menhir is offline
post #10 of 19 (permalink) Old 06-04-2019, 11:49 PM
Hope it does.
Best of luck!
Glad your ride home was a little better.
