anyone deal with this? broke exhaust stud - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 4 (permalink) Old 06-04-2019, 10:45 AM Thread Starter
yea.................drill into engine block anyone?
iv drilled these bolts and that's it. I need to get some extractors.
cobra pipes. pulled off to wrap (burning leg)
so anyone know what size extractor I should use?
busted one on each pipe. replacing with Honda civic clutch bolts. super grade 899389. never have busted one of those not sure what grade they are
rabies is offline
post #2 of 4 (permalink) Old 06-07-2019, 02:49 PM
good luck drilling and extracting. May need to rethread to clean out the thread. I would use normal stainless steel bolts and don't forget the anti seize.
JulyRC is offline
post #3 of 4 (permalink) Old 06-07-2019, 04:40 PM
Keep a steady hand.
I've found it helps to use a center punch and then a center drill and then a drill.
I have an '08 C50.
Paraquat is offline
post #4 of 4 (permalink) Old 06-10-2019, 10:34 AM Thread Starter
xtractors didn't work. drilled out and jammed bigger bolts in. it holds.
rabies is offline
